Latest post 07-24-2007 9:47 AM by wirralsimon. 3 replies.
Page 1 of 1 (4 items)
  • 07-24-2007 6:59 AM
    Avant 28" Question
    I have been tracking a 28" Avant on Ebay. It has a built-in VCR and have established that it is a type 8133, looking that up in the products section establishes that it is a
    BeoVision Avant 50Hz MK I MK II (81xx)
    I did a search earlier and it seems that some of the earlier 28" Avants are best avoided as they are prone to tube problems. Is this one of the ones I should avoid?
    Many thanks
    Simon
  • 07-24-2007 7:58 AM In reply to
    Re: Avant 28" Question
    In Holland a dealer told that the 50 Hz tubes had the problem. So I would aim for a 100Hz, better tube, sharper image.
    I bougth one myself and when you are used looking at the 100Hz, you see the flickering (is this good English?) at the 50Hz tubes.
    I have a 100 Hz Avant and a 50Hz Mx 4000 and Mx 1500 and I see that the image on the Avant is much, much better.
    You do not own B&O, it owns you!
  • 07-24-2007 9:06 AM In reply to
    hi simon,
    I'd go for the 100hz instead of a 50hz for the difference is huge : it's the best picture in town !
    another reason : the 50hz is older, with a more troublesome tube and my [100hz] avant has a superior picture compared to
    my [50hz] mx4000
    Leon: Beoworld's First "First Prize" winner. "Carpe Diem et Dolce Far Niente"
  • 07-24-2007 9:47 AM In reply to
    Thankyou!
     I'll let the auction pass me by.
     Simon
