Latest post 07-21-2007 1:46 PM by Peter. 1 replies.
Page 1 of 1 (2 items)
  • 07-21-2007 12:12 PM
    Compatability
    Hi
    I have recently acquired a TV MX2000 and Video VX5000 and have ordered the Video Terminal remote for the TV.  Can anyone tell me if the TV and Video are compatible?  Do I need a separate remote for the video?  Any hints would be appreciated ie. how to set up the channels on the telly.
    Cheers
  • 07-21-2007 1:46 PM In reply to
    Re: Compatability
    You will need a Beolink 1000 and an external sensor. The sensor is much the same as a MCL sensor but will need wiring to a DIN plug.
    I would actually make sure the VX5000 works first and then strongly suggest getting a different TV. An LX2502/2802 would give you a far better picture and sound and are practically given away these days. These will stop you needing the sensor and will possibly be cheaper than finding one!! An MX5000 would also suffice if you prefer this style.
