Latest post 03-01-2012 1:30 AM by elephant. 1 replies.
Page 1 of 1 (2 items)
  • 02-29-2012 7:34 PM
    Beolit Beoclock Apps
    Sorry if these have been mentioned elsewhere, but I just noticed that the iPhone/iPad app store now has a Beolit Setup App. It also says Beolit software updates will be available through the App.
    There is also an App called BeoClock. It is not from B and O but says it was inspired by the Beosound 5.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 03-01-2012 1:30 AM In reply to
    Re: Beolit Beoclock Apps
    Razlaw:
    A laser-pointer minute hand ?
    I was hoping for something more inspired/inspiring .....
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
