I crack it, I went on the sky web site and tried all of the codes listed but none would work, then after a lot of patientence found code 0593 will adjust the tv turn the tv, but unfortunatly will not turn the tv on.
So all is all that ok and the kids just have to use the be05 to turn the tv on then they can use the sky remote without me getting worried that they are going to break it, drop it etc
Regards
