Hello my dear fellow BeoWorld-members :)
I have not posted anything here before and just recently became a member but I have been reading the forum and product pages on BeoWorld for many years now. But today I am doing my first post here!
Yesterday I bought a used BS9000 mark2 and it was already powered down and they had all cables and such disconnected and put in a box for me when I arrived to pick it up. I got it for a fairly good price(I think) and the seller told me it was in excellent condition.
Unfortunately that was not totally true. It is indeed in good cosmetic condition BUT it seems to have one big problem and that is the glass door-motor (I think). They had it mounted on a wall (which I am going to do also). When I got home I took the wall mount of and adjusted the screws on the back to the mode for placing it on a table (just to try it out). I let it rest for a while and then powered up the Beosound.
It behaved a bit strange.. When I tried to open the glass door it began opening and after a few seconds it fell down, like it couldnt drive it all the way up.
After that it behaved very strange(rebooting and such) and I realise it is probably because it didnt understand what happened. After a few hours and cleaning of the glass door and the complete BS9000 (took the glass door off, screwed out the two torx-screws and put it back together) I realised that it works only if I help with my hand to take som load of the engine. It can't even hold the door open by itself.
Im not sure why this is and I have checked the screws that holds the glass door to the hinges and they are very tight now and it still does this. It seems like perhaps the engine is to weak or that something has broken inside. Very strange.
After the cleaning it did however work great when I helped with my hand. The player is working and moves fast between CDs, it was slow when I got it but I realise it was because of the dust on the optical sensors.
The selled DID tell me, when I was leaving to let it rest for hours after plugging the power in before using it. Don't understand why but he said so. They had it connected to a linksystem and I changed it to option 1 for now.
Perhaps the engine can bear the weight of the glass door when it is put on a wall but not on a table and that might be why they didn't say anything? It seems like it could be possible to fix and I am _very_ technical and wouldnt hesitate to try and fix it myself but I am asking here first for help on the issue. Searching the forums I couldn't find any information on this matter.
That was my problem, now my question :). Since this is a Mark2 it doesnt have support for N.MUSIC/N.RADIO (I checked, it says phono etc.) so I was thinking about upgrading to a newer chip. Have looked at the guides and it seems quite simple to put a new chip in. Now the problem is of course to get the chip!!
I went to my B&O dealer and they are very helpful. I got a number to the service center they used and called them today. Unfortunately they was not as helpful, actually they were downright arrogant and extremely uninterested in helping me with this. Prehaps just a bad day for the guy I talked with but I was very disappointed when he told me that they didnt want to help me aquireing the chip itself (guess they want to charge for the job).
Of course I also want a new engine if that is the matter and he was even more uninterested in helping me with that..
Please, what should I do?
I have to say I don't think the seller was lying to me, he was very friendly and seemed very truthful. I might call him and see what he says about the issue but I want to check it up first. I am a geek and love to fix broken things (which I often do). Almost like it better to buy broken things than things that work :-).
I live in Sweden and I don't know the best way to buy the parts I need. Perhaps anyone here has/is a good contact or something that can help me.
I was thinking about using a BeoPort connected to a mac-server for N.MUSIC and N.RADIO and I bought the BS9000 because it is so classy and flexible, which I don't think is the case with the BeoSound 5 unfortunately..
Sorry for the loong post but remember, it is my first! :D
