Hello all,
Is it possible to use the BeoMaster 5 without a BeoSound 5?
Just use the BV10 and Beo6 to control the BM5?
Does the bidi communication between the Beo6 and the BM5 then give you the whole functionality?
Regards,
- Flere
It's possible
toshiba pa3588u-1brs ,toshiba pa3588u-1brs Ladegerät, Ac Adapter - 35% Rabatt toshiba pa3588u-1brs Notebook Akku,toshiba pa3588u-1brs Aufladegerät, 2 Jahr Garantie, Hohe Qualität !
Flere: Hello all, Is it possible to use the BeoMaster 5 without a BeoSound 5? Just use the BV10 and Beo6 to control the BM5? Does the bidi communication between the Beo6 and the BM5 then give you the whole functionality? Regards, - Flere
Yes but the display will not look the same (it's the same as BeoMedia essentially) and the two way features of the remote will not work.
