Latest post 02-12-2012 5:05 AM by kimhav. 0 replies.
Page 1 of 1 (1 items)
  • 02-12-2012 5:05 AM
    • kimhav
    • Top 500 Contributor
    • Joined on 09-03-2007
    • Sweden
    • Posts 127
    ML Socket together with CAT7
    I will soon wrap up my re-wiring project in my house and where CAT7 cable has been used for the MasterLink network. In my case I wanted to make use of ML-sockets on several spots in the house which then directly connects to the units; but from this thread it's mentioned that the since the CAT7 cabling is missing "+ Supply Voltage" I then need to solder together ML-Sense (pin 03) and +Supply (pin 12) to get it to work proper. Simply I don't like to have end the CAT7 with a RJ45 socket and the contininue with the B&O RJ45 to ML socket cable.
    Open for suggestions and images how to do above in best practice way.
