Latest post 02-07-2012 5:44 PM by Opman. 6 replies.
Page 1 of 1 (7 items)
  • 02-07-2012 4:48 PM
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    A.Aux in link room
    Hello All
    I have a BeoSound3000 in lounge with Lab4000's. I also have a pair of CX50's in kitchen on a Link Passive.
    BeoSound3000 is in option 1 and Passive kit is option 4 as its open plan and commands used to "sneak" to the kitchen hence the need for the "link" command.
    I have just installed an Airport Express to the A.Aux socket of the BeoSound3000 and it all works fine. I can only access this source in the kitchen by manually pressing the Passive sensor after first switching on A.Aux in the lounge.
    Is there a way of opening the link to the kitchen via remote? I normally use BeoLink1000 in the kitchen but also have a Beo4 in the lounge.
    Opman
  • 02-07-2012 4:54 PM In reply to
    Re: A.Aux in link room
    does the passive have old software?
    have u tried a mem instead of v aux?
  • 02-07-2012 4:56 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Opman:
    Depending which SW version your BSd 3000 and Passive have,
    using the BL1000 and pressing "LINK" "PHONO" might work.
  • 02-07-2012 5:20 PM In reply to
    • Emil
    • Top 500 Contributor
    • Joined on 05-18-2007
    • Stockholm, Sweden
    • Posts 98
    Link + a.mem / a.tape should do the trick on a beo4.
    Inflagrante
  • 02-07-2012 5:24 PM In reply to
    Have similar setup and have the same problem with A Aux. Suggested Commands does not work.
    _____________
    Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
    1:st prize winner Beoworld January Price Draw.
  • 02-07-2012 5:42 PM In reply to
    • Opman
    • Cheshire, UK
    • Posts 323
    Success :-)
    Link + A.Tape on the BeoLink1000 does the trick.
    The BeoSound3000 display shows the source changes from A.Aux to A.Tape but I still get the Airport Express in the kitchen.
    Result.
    Thanks for the suggestions
    Opman
  • 02-07-2012 5:44 PM In reply to
    • Opman
    • Cheshire, UK
    • Posts 323
    For the record, Link + Phono command to the Link Passive = N.Radio on the BeoSound3000
    Opman
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
