Latest post 02-06-2012 2:30 PM by Medogsfat. 1 replies.
Page 1 of 1 (2 items)
  • 02-05-2012 10:27 AM
    • crd101
    • Not Ranked
    • Joined on 01-26-2012
    • Posts 7
    Grounding BG1700 to BM901
    Does anyone know where I ground my 1700 (it uses RCA) to my Beomaster?
  • 02-06-2012 2:30 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Grounding BG1700 to BM901
    Why RCA? I can only assume someone has removed the original plug?
    The original output lead of the BG1700 had a DIN plug - the outer metal casing/shield of the DIN plug is the grounding point to the input socket on the 901.
    Chris.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
