For this Light Contol LC2 Type 2131 SW 1.1 Serial No. 10805376 it is possible to operate  "on / off  and dimm" with Beolink 1000 and 7000.
To operate the LC2 Type 2131 SW 1.1 Serial No. 10805376 by touching the sensor point by hand directly, there is no funktion.
To change the LC2 Type 2131 SW 1.1 Serial No. 10805376 with Beolink 1000 or 7000 into "on / off " function, refered to instruction manual has failed.
Is it possible that the SW 1.1 version is not working with Beolink 1000 and 7000?
Thanks for your kind support.
Best regards
Celtic_stories
