Latest post 01-27-2012 9:01 AM by ralfja. 2 replies.
Page 1 of 1 (3 items)
  • 01-26-2012 5:57 PM
    Terminal 3300 remote controller
    Greetings and thank you for anyone's time to reply.
    Will  the Terminal 3300 remote will operate a Beomaster 3000?
    It looks the most similar to any I have seen.
    Is there a recommended facility to repair a Terminal 3000 remote?
    Chuck K.
    from the states
  • 01-27-2012 8:39 AM In reply to
    Re: Terminal 3300 remote controller
    Unfortunately, although they do look the same, they don't use the same codes.
    B&O probably will not want to repair it, but a good/motivated repairman should be able to at least diagnose the fault and maybe repair it. There might be a forum member here who can too!
  • 01-27-2012 9:01 AM In reply to
    Excatly. The Terminal 3300 uses the newer codes which are compatibe to Beolink 1000, Beo4, etc.
    Beomaster 3000 uses unique codes which are only compatible with Terminal 3000. I got one here: http://www.lifestyle-av.co.uk/product_list.asp?sectionId=4 a few months back.
