Latest post 02-08-2012 5:05 AM by rudolffischer. 5 replies.
Page 1 of 1 (6 items)
  • 01-22-2012 5:32 PM
    Beolink 5000 - Beocenter 2300 - how to clear "timer play"
    I have programmed my Beocenter 2300 to wake me up every day of the week with radio in the morning using the Timer Play function on the Beolink 5000. This works fine. But now I would like to turn off the Timer Play and I just cannot find any way to do it. The Beocenter keeps waking me every morning.
    Am I missing something?
    Thanks and regards
    Rudi
  • 01-23-2012 3:24 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: Beolink 5000 - Beocenter 2300 - how to clear "timer play"
    Isn't there a timer button on the 2300?
    Should turn the green timer light off...
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 01-23-2012 3:43 AM In reply to
    Hi Ralf
    you saved my day. Pressing "Mute" on the 2300 was the solution, as outlined in this thread.
    http://forum.beoworld.org/forums/p/19304/143602.aspx#143602
    Thanks a million
    Rudi
  • 02-08-2012 4:13 AM In reply to
    I have posted a follow on question at the end of this thread, as it seems to raise the same issue:
    http://forum.beoworld.org/forums/p/19304/357860.aspx#357860
  • 02-08-2012 4:51 AM In reply to
    • Weebyx
    • Top 200 Contributor
    • Joined on 06-30-2008
    • Denmark
    • Posts 321
    You can clear timers using the Beolink 5000 remote... You just go into programming mode, and with the appropriate timer play/recording visible in the display, you just press "clear" on the remote. It will ask you to clear the timer....
    Voila :)
    /Weebyx
  • 02-08-2012 5:05 AM In reply to
    ok, I think I finally got it:
    Program -> chose "Timer Play" -> Chose "Audio System" -> Press "Status" -> Press "Clear"
    Not quite intuitive, but easy once you get it.
    I had five timers programmed one on top of the other.
    Thanks a lot Weebyx, you're a genius
    Rudi
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
