Latest post 01-29-2012 5:06 PM by Blackrix. 8 replies.
Page 1 of 1 (9 items)
  • 01-22-2012 1:46 PM
    Beogram 8000 platenspeler
    Hallo Beogram fans, ik probeer een beogram 8000 platenspeler op m'n 'gewone' versterker (medevoort) aan te sluiten. Ik heb alle benodigde (koppel) kabels en een apparte pre-amp. Nu blijft het geluid er niet zuiver uit blijven komen (vervorming). Ik heb inmiddels 3 elementen geprobeerd (mmc20e, MMC20S en de mmc20cl).
    aangesloten op tape en line.  Iemand een tip voor me>??
  • 01-29-2012 12:26 PM In reply to
    Re: Beogram 8000 platenspeler
    Geen idee. Werkt de BG8000 wel goed met een Beomaster?
  • 01-29-2012 1:08 PM In reply to
    How is the tracking force, it should be just about 1,2-1,6 grams. There is a scale on the right side of the tonearm.
    I could also sound like the pre-amp is overloading because of too high sensitivity. What preamp are you using?
    Sorry for not answering in Dutch, but I can't write in that language Smile
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 01-29-2012 1:14 PM In reply to
    Thanks anyway for your reply. Always good to see that people remain involved in Beogram stuff.
    It is an 'regular' (nameless) (R?)IAA peamp, I already ajusted the tracking force (it was indeed to low). In the beginning everything seems te operate well, but after 10-20 minutes the sound start to deform! Perhaps it is an IC of capacitor? thanks,. Max
  • 01-29-2012 1:56 PM In reply to
    The sound goes straight from the stylus to your preamp. There are no electronics in between. Are you sure the preamp is OK?
  • 01-29-2012 2:11 PM In reply to
    Thanks, I'll buy anothter one to try it out. Sometimes the speed differs alo in between, resulting in an fase sound. Sometimes it is ok the complete record.. It seems the machine did not play a while Wink Perhaps a bit of grease? thanks Max
  • 01-29-2012 3:12 PM In reply to
    De BeoGram 8000 kan problemen hebben met een aantal condensatoren wat een aantal problemen kan veroorzaken. Het vervangen van de condensatoren is geen overbodige luxe bij deze BeoGram.
  • 01-29-2012 4:27 PM In reply to
    Yes, that can absolutely be a capacitor problem, but it's also possible that there is dirt on the speed governor which is a metal disc with square holes along the edge for reading speed. It's under the subplatter. I cleaned mine when it had speed problems and they dissapeared Smile
  • 01-29-2012 5:06 PM In reply to
    I forgot that one. In the BeoGram 8000 the metal disc can also be a plastic disc on which the square holes are printed. Most of the time the printing is getting bad. In that case it should be replaced by a metal one. I think Martin (Dillen) can supply these discs?
