Latest post 01-22-2012 11:46 AM by Seanie_230. 3 replies.
Page 1 of 1 (4 items)
  • 01-21-2012 2:52 PM
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Beolink convertor help
    Hi all
    I have had a 9300 connected to my system for about two years via a beolink convertor.
    This week I removed the 9300 and convertor as I was having some plastering done.
    Now it's all reconnected the 9300 is not powering up from anywhere on the ML.
    It works locally only reset the options on the main room tv and the 9300 but nothing.
    I switched everything off one by one and this has not helped.
    Any ideas
    Thans
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 01-21-2012 3:31 PM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: Beolink convertor help
    Also everything is connected as it was before.
    Driving me mad that they did not put any form of indicator on this device
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 01-21-2012 6:10 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Just an idea, a 7pin DIN of the AV cable also fits into the 8pin PowerLink socket of the BeoLink Converter ...
  • 01-22-2012 11:46 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Hi there
    Problem solved, well it will be when I can be bothered to get under the floor.
    Seems with all of the movement the green cable is not connected anymore.
    I got out the trusty old multi meter and buzzed out each cable.
    Turns out green is data and that is currently missing in action.
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
