Latest post 01-20-2012 4:58 PM by Step1. 2 replies.
Page 1 of 1 (3 items)
  • 01-16-2012 8:37 PM
    beomaster5500 need help now
    The sound comes out though the speaker.With the cd player it sounds low and like a radio station that wont come in.The cassette deck it is clear but muffled and low.The volume does go up and down alittle.Any ideas
  • 01-20-2012 2:41 PM In reply to
    Re: beomaster5500 need help now
    First of all check your connections, cables, jacks, plugs, correctly connected and not broken, all clean and if that does not help, try other CD/tape players, last open your BM and start looking for failures there.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 01-20-2012 4:58 PM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    so all sources have similar problem. Try speaker 2?
    Olly.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
