Hi all,
I recently acquired a 1202 in decent condition, and after some cleaning and wood repairs to the plynth, appears to be nearly new! all the functions work fine, the motor gets up to speak fine, the auto functions of the arm work fine, the records play at the right speeds.. but! the signal is very quiet and is accompanied by a loud but high-to-mid pitched hum. And the sound is only coming from one speaker. I have attached the 1202 to a modern amp by using a 5pin DIN to phonos adaptor (admittedly a cheap one, as I wanted to know if the record player worked before forking out on a proper one from Sounds Heavenly). When the amp is cranked right up, we can hear the record playing fine, with no distortion, so I think the cartridge (an SP14) and the stylus are both fine. I am thinking it must be a minor problem with the output - perhaps the wire itself or the connections inside. Can anyone shed any light on this for me?
George
