Latest post 01-02-2012 5:20 AM by Keith Saunders. 5 replies.
Page 1 of 1 (6 items)
  • 01-01-2012 12:20 PM
    Beocom 6000 - no signal
    Hi
    We have 2 beocom 6000's. In the last week, one has decided to play up. It charges fine, still shows all the contacts, but shows 'no signal' and there is no dial tone. It will not allow me to enter the menu to make any changes. Any ideas anyone?
    Thanks and Happy New Year
  • 01-01-2012 1:15 PM In reply to
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    Re: Beocom 6000 - no signal
    This may sound odd, but I had a similar issue a few days ago (one phone working fine, the other "no signal"), and resolved it by unplugging the base station (the unit that is connected to the phone lines) from power, waiting ~30 secs, then plugging it back in.  You might also try disconnecting the battery in the Beocom, and then reconnecting (I did this, too, but it didn't fix it...).
    Stan
  • 01-01-2012 2:02 PM In reply to
    Thanks Stan.
    Tried that but with no luck - thanks anyway.
    Does anyone else have any ideas?
    Rob
  • 01-01-2012 3:11 PM In reply to
    Shatterwell:
    Assuming your Beocom 6000 is a Mark I, then you have the classic problem where the RF chip has failed on the PCB
    If you have a Mark I Beocom 6000, then you dial face will look like THIS
    You can no longer get the Mark I PCB because the RF chips are no longer made, but you can get an upgrade kit which will make it into a Mark II
    Regards Keith....
  • 01-02-2012 4:27 AM In reply to
    Thanks Keith. Any ideas where I could get one?
    Regards
    Rob
  • 01-02-2012 5:20 AM In reply to
    You can only get an upgrade kit from a B&O dealer and the kits contains the items shown HERE
    As the upgrade kit is a spare part, not all dealers are prepared to sell it and prices will vary.
    Regards Keith....
