Latest post 12-28-2011 2:20 PM by Sevilsivle. 2 replies.
Page 1 of 1 (3 items)
  • 12-28-2011 5:22 AM
    BeoPlayer App
    Hello Beoworlders,
    all the radio stations have disapperared from the BeoPlayer App installed on my iPhone.
    The favourites list is empty and any attempt to search for stations causes the app to crash. Anyone with the same problem?
    I only use the app occasionally so I have no idea if this has only happened recently, a couple of weeks ago it worked fine.
    regards
    Tim
  • 12-28-2011 12:03 PM In reply to
    Re: BeoPlayer App
    Sevilsivle:
    Hello Beoworlders,
    Just checked: iPod Touch 4g WIFI: Radio stations: It is workin fine
    Music on my iPod: choosing a title (on my iPod) and starting: the title is played, but the app shuts down (music still playing)
    Restarting the app I get into the radio section (last station I listened to before switchin to music)
    Resumé:
    There is still room for improvement in the music section.
    Some speculations about your iPhone:
    Did you restore your iPhone during the last weeks?
    Did you try to reinstall the BeoPlayer?
    iPoditiv
  • 12-28-2011 2:20 PM In reply to
    Re: BeoPlayer App
    I have reinstalled it and now I can select from the list of radio stations, although the preset list of favourites is gone. I moved everything across to my new iMac Big Smile over Christmas perhaps that was the problem.
    I think there are now more stations than there was when I installed it originally. I just need to redefine a few favourites.
    Tim
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
