Latest post 01-17-2012 8:44 AM by Chris. 5 replies.
Page 1 of 1 (6 items)
  • 12-28-2011 4:21 AM
    • Chris
    • Top 500 Contributor
    • Joined on 05-09-2010
    • Last of the Summer Wine Country, Yorkshire, UK
    • Posts 195
    • Gold Member
    Schmartz PS3IRX1 IR to PS3 USB Adapter
    I've been looking at RE-BL, Bossbridge and this Schmartz - IR to PS3 converters.
    Does anyone have experience with this Schmartz? And is it Beo5 compatible?
    Beosound 8, Beotalk 1100, Beocom 4, A8 Headphones, Form 2 Headphones, Apple iPhone 4S, iPod Classic, iPad 1, Sky+ HD, Sony Playstation 3, Jacob Jensen T10, Lutron Rania IR Dual Dimmer/ Accesory dimmer, B+O A9 Keyring (SOLD), Beolit 600 (SOLD), Apple Airport Express, Beo5
  • 12-28-2011 12:01 PM In reply to
    Re: Schmartz PS3IRX1 IR to PS3 USB Adapter
    I made an XML file for the WB Electronics version back in 2009. If this version uses different IR codes, then we can certainly make an XML file for it.
    Regards Keith....
  • 12-28-2011 12:15 PM In reply to
    • Chris
    • Posts 195
    • Gold Member
    Is there anything you cannot do when it comes to the Beo5? Stick out tongue
  • 12-28-2011 12:31 PM In reply to
    I have just looked at the company's web site and helpfully they have provided all the codes in Philips Pronto HEX format which I can convert without any problems.
    Regards Keith....
  • 12-28-2011 12:35 PM In reply to
    • Chris
    • Posts 195
    • Gold Member
    Thanks - this seems much cheaper than RE-BL or Bossbridge - not sure of any differences.
  • 01-17-2012 8:44 AM In reply to
    • Chris
    • Posts 195
    • Gold Member
    The pro version on the download page works perfectly!
