Latest post 01-05-2012 5:35 PM by Leslie. 7 replies.
Page 1 of 1 (8 items)
  • 12-18-2011 12:35 AM
    MMC1-5 cartridge (in fair or poor condition)
    Hi!
    I have a Beogram 6002 under restoration and a Beocenter 7700 coming my way, but not a suitable cartridge for them!
    I'm looking for a MMCn-series cartridge for mainly tuning and adjusting the tonearms and mechanics, so it is a bonus if stylus is good enough to get any sound out of it.
    If You have a spare cartridge - any of the MMC1-MMC5 series will do, in fair or poor condition - that You are willing to part for a reasonable sum of money let me know!
    - Jari
  • 12-18-2011 4:42 AM In reply to
    Re: MMC1-5 cartridge (in fair or poor condition)
    If it's for testing purposes I could lend you one!
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 12-19-2011 1:34 AM In reply to
    Thanks, Leslie! Sent You a PM!
  • 12-19-2011 3:39 PM In reply to
    Got it! Will post this week (MMC4) to Suomi!
  • 12-20-2011 12:41 AM In reply to
    Great! Thanks a lot, Leslie!
    - Jari
  • 12-23-2011 6:10 PM In reply to
    Bit more patience Jari, have to buy some small jewelry boxes to put in all my MMC's and SP's I've collected. Will definetely post yours beginning next week!
  • 01-05-2012 3:12 PM In reply to
    try an sd card plastic case, once closed it will hold the stylus in place without causing any damage, plus you can see at a glance which mmc is inside
    regards jay
    jason
  • 01-05-2012 5:35 PM In reply to
    Iconic-AV:
    regards jay
    Thanks for the tip Jay!Yes -  thumbs up
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
