Latest post 12-14-2011 8:11 AM by beowild. 4 replies.
Page 1 of 1 (5 items)
  • 12-13-2011 12:50 PM
    Powerlink up to what length?
    Hi everybody
    Anybody knows up to what length you can use Powerlink Cables without having distortion or noise you can hear?
    Perhaps a silly question but i haven't found the answer in the faq or older posts.
    All suggestions are very appreciated.
    Best regards
    David
  • 12-13-2011 1:24 PM In reply to
    • Joe
    • Not Ranked
    • Joined on 10-03-2007
    • SoCal
    • Posts 74
    Re: Powerlink up to what length?
    The longest pre-terminated Powerlink cable made is 20 meters(66 feets). Do you need a cable longer than that?
    Joe
    Its not just a product, its a way of life...
  • 12-13-2011 2:16 PM In reply to
    Hi
    Yes, thinking about 30 to 35 m.
    best regards
    David
  • 12-14-2011 3:17 AM In reply to
    • SWISS_2
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    My experience with one run of two 20M Powerlink cables a few years ago was that the sound was a little " noisy " at first.
    I moved two appliances nearby ( a television and an SSB radio ) and that did not solve the sound quality. We have much electronics around here. I then ran hard silicone conduit with the Powerlinks inside, and that solved the problem for the moment.
    Along came Master-link, and that changed everything. One M-L run only, shorter mains/electrical powerlink connections close to each amplified speaker, with the result of much better sound being produced, including N.MUSIC and N.RADIO Internet sources.
  • 12-14-2011 8:11 AM In reply to
    Hi
    Thanks for all the information.
    best regards
    David
