I trust you have tried cleaning the CD lense?
The real problem is more likely a capacitor. Do a search on the forum for 'C2103' and you'll find lots of imformation. It has to be a particular brand of capacitor and best obtained by sending a PM to our member 'Dillen'. Don't ask him via the forum as he's unlikely to get your message.
Armed with the kit he supplies you can then find someone to install it. You'll need a copy of the service manual for disassembly instructions.
Steve
If you think nobody cares, try missing a couple of payments.
