Latest post 12-07-2011 5:16 PM by Daniel. 4 replies.
Page 1 of 1 (5 items)
  • 12-06-2011 2:36 PM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Small linked system - help please!
    Hi all,
    Have a BV6 without ml socket, I want to create a master slave system with a BS4, how do I do it(My downloaded copy of the ML system is on my laptop which is currently under warranty repair)
    The BS4 is currently connected to an MX7000 via a converter box but that uses the audio output socket of the tv which of course there isn't on the BV6   ---------    Help please!!!
    Tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 12-07-2011 4:34 AM In reply to
    Re: Small linked system - help please!
    Hi - I think you are trying to connect the new BV6 to the BS4 as a replacement for the MX7000 ?
    And you want to do it without having to upgrade the BV6 by having the MasterLink system module added ?
    This takes one down the path of trying to link one unit's audio out to the other unit's audio in.
    I presume your speakers are attached to the BS4 ?
    The BS4 has an AUX-IN, so the question is how to get the audio out from the BV6 into the AUX-IN of the BS4 ?
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 12-07-2011 6:02 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    stotty1111:
    That's not audio output, it's Datalink (socket is named "Audio Aux Link"), a predecessor to ML. Your converter is a Beolink Converter. The only way to get the same with BV6 is to install a ML module. No need for the converter box any longer (if you skip the MX).
  • 12-07-2011 8:18 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Just viewed the 6-26 no probs, it has an ml socket - panic over!!
    Cheers men!
    Tony
  • 12-07-2011 5:16 PM In reply to
    • Daniel
    • Svinarp, Sweden
    • Posts 1,284
    stotty1111:
    Cheers men!
    Tony
    Beer
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
