Latest post 12-04-2011 6:16 PM by kai. 1 replies.
Page 1 of 1 (2 items)
  • 12-04-2011 4:51 PM
    • alvar
    • Not Ranked
    • Joined on 09-26-2010
    • Posts 2
    changing Beovision 5 grille/fret
    Dear friends,
    After successfully remove the aluminium frame of my BV 5 I'm not able to remove the cloth grill. I have tried to unscrew the silver bolts around the grille but the panel rejects to be removed, any ideas will be welcome.
  • 12-04-2011 6:16 PM In reply to
    • kai
    • Top 500 Contributor
    • Joined on 11-16-2008
    • Posts 81
    Re: changing Beovision 5 grille/fret
    I remember doing this for a customer once the the frame has been removed you remove all the screws surrounding the fret ( there are a few) it should be a case of simply grabbing the top of the fret and you should be able to take it out from there
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
