Latest post 07-12-2007 4:19 PM by The Stig - ver. 1.7. 1 replies.
Page 1 of 1 (2 items)
  • 07-12-2007 3:36 PM
    is the BeoVision 9 modular ???
    Hello Everybody!
    daes anyone know if the BeoVision 9 is as MODULAR as the BeoVision 4?
    I mean, I really like the fact of the BV 4 being so modular... in theory you could replace the panel after a while and keep the BeoSystem 3... and if you had a HDR2 you could keep that too...
    would it be the same with the BeoVision 9?
    thanks and many regards!
  • 07-12-2007 4:19 PM In reply to
    Re: is the BeoVision 9 modular ???
    In theory yes.
    The BV9 has the following: BL7-4, BS3, HDR2, Beomedia1 and BV4 panel. So in theory you can bay a BV4 and chance it if it still use the same bracket as it do today..
