Hi All, i have below, 220v-Power info for BeoVision 6-26, does anyone know
what I should get to convert into 110v, I need specifications for New York-USA usage,
Thanks for any info.
rOn
Hi Ron! You can bring it to any of the stores in the city and we can have the voltage converted for you. Not sure where you're located but my shop is on 21st street and Broadway. Sadly this model was never designed to work in the US so don't expect the STB-C or tv tuner(s) to work. Hope this helps!
Thanks, much appreciated, what is STB? Do you mean im not able to use it a a TV, w/TMC or verizon fios? thanks.
o0l0o: Thanks, much appreciated, what is STB? Do you mean im not able to use it a a TV, w/TMC or verizon fios? thanks.
Well you'll be able to connect your sources to it (with some adapters), but you will not be able to control them using the Beo4/5/6. I should be at the store today if you would like a little bit more concise an explanation. +1(212)388-9792
