Latest post 11-24-2011 5:06 PM by Toralfsen. 3 replies.
Page 1 of 1 (4 items)
  • 11-23-2011 5:53 PM
    BV7-40 + bl7-2: will it make sence to add bl4 as rear speakers?
    Will it make sence to add the bl4 as rear speakers?
    will I be able to use the sorround of the bv7-40 mkIV?
    adding front speaker is not an option unfortunately..
  • 11-23-2011 6:09 PM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: BV7-40 bl7-2: will it make sence to add bl4 as rear speakers?
    No fronts - no rears... Reals only make sense with fronts... Check the internet for 5.1 Sound/Dolby digital etc. to learn more about it.
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 11-23-2011 6:47 PM In reply to
    Is the beolab 7-2 not acting as both front and center if I add BL4?
  • 11-24-2011 5:06 PM In reply to
    As far as I know you can|t add configure them in setup. If you have some speakers to connect when you set up the TV, then you can remove them. In speaker 5-mode you will have center and rear. (You will lose right and left front.) Speaker 1 works as before...
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
