Latest post 11-25-2011 6:21 AM by Chris. 5 replies.
Page 1 of 1 (6 items)
  • 11-23-2011 4:37 PM
    • Chris
    • Top 500 Contributor
    • Joined on 05-09-2010
    • Last of the Summer Wine Country, Yorkshire, UK
    • Posts 195
    • Gold Member
    Beo4 and Apple iTunes
    Sorry all, another remote control question.
    Is it possible to control Apple iTunes using a Beo4 remote control? If so, is there anyrthing that would extend the range on the Apple Macbook remote eye - which is usually located upstairs and my Apple Airport express connected Beosound 8 located downstairs?
    Thanks!
    Beosound 8, Beotalk 1100, Beocom 4, A8 Headphones, Form 2 Headphones, Apple iPhone 4S, iPod Classic, iPad 1, Sky+ HD, Sony Playstation 3, Jacob Jensen T10, Lutron Rania IR Dual Dimmer/ Accesory dimmer, B+O A9 Keyring (SOLD), Beolit 600 (SOLD), Apple Airport Express, Beo5
  • 11-23-2011 6:04 PM In reply to
    • Emil
    • Joined on 05-18-2007
    • Stockholm, Sweden
    • Posts 98
    Re: Beo4 and Apple iTunes
    Have not tried this product myself but maybe there are others who has?
    http://eu.bosscom.com/product.asp?id=1091
    Inflagrante
  • 11-23-2011 6:13 PM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Let us see how long this will b here... The .... Company is NOT a friend of this site!?!
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 11-23-2011 6:19 PM In reply to
    • Emil
    • Stockholm, Sweden
    • Posts 98
    Unfortunately nothing I was aware of despite being a regular visitor of the forum. My excuses if that would be the case.
    Inflagrante
  • 11-24-2011 2:17 AM In reply to
    Pretty sure Judith gave a review of her difficulties with the company/device mentioned above.
    The simplest (but not most economical) solutions are:
    1/ consider a BeoPort, or
    2/ invest in a Beo6 (not sure of its range)
    assuming of course that you have some form of a masterlink or Beolink Wireliss setup in place ...
    Now I have reread the OP I wish I could delete my response :-)
    So now I am not sure what is the best approach for you ... do you have anly plans to expand your B&O equipment in the future ?
    And if not, do you have an iPad, iTouch or iPhone that you can use the Remote app on to provide remote control wirelessly up to the iTunes that will then broadcast the sound wirelessly back down to the Airport Express/BS8 combo ....
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 11-25-2011 6:21 AM In reply to
    • Chris
    • Posts 195
    • Gold Member
    Currently using Apple Remote app to control Itunes via iPhone or iPad but can be a pain starting and stopping the app - I love Apple but to control the Macbook via a Beo4 would be cool!
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
