Latest post 11-22-2011 3:57 PM by richh. 6 replies.
Page 1 of 1 (7 items)
  • 11-20-2011 4:16 PM
    • richh
    • Not Ranked
    • Joined on 11-06-2011
    • Posts 7
    speed adjustment ???????????
    Hi ,
    I have a beogram 1500 to match my beomaster 1500. I love the quality and retro looks but have had a few niggles.I think most are down to age.
    The problem I'm most interested in is soting my record speed out. My deck seems to play a little fast ! Not ridiculously so but enough for me to notice. Is there a way to adjust the 33 rpm to "just " right ?
    The other niggle is thqt at the end of a record the arm just swings across the record without lifting.It lifts when "pausing" so I know all the mechanics are ok
    Help with the speed would really be the priority as I want to enjoy my stock of old albums
    Any help gratefully received
    Cheers
    Rich
  • 11-20-2011 5:01 PM In reply to
    Re: speed adjustment ???????????
    We need to know the type of your 1500, 57xx or something like it
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 11-21-2011 3:26 PM In reply to
    • richh
    • Not Ranked
    • Posts 7
    The model I have is a BG1500 5714 type
    Hope this helps
    Rich
  • 11-21-2011 5:21 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Doesn't the fine speed adjustment (small fingerwheel) work ?
    The slow (or completely missing) arm lift is caused by dried out lubricants.
    We've had that several times, also with Beogram 2200 and 2400 models.
    Do a search and you will find a photo of the dry spot or maybe another member
    has a bookmark.
  • 11-21-2011 5:34 PM In reply to
    Didnt find the BG 1500 manual, but you may look for 2 pcs potentiometers for speed adjustment, here the manual for 1102, belt drive, you may have a speed selector for +- speed or not, the adjustments may be under the platter, under the top cover or through holes in the buttom plate.
  • 11-22-2011 3:55 PM In reply to
    • richh
    • Not Ranked
    • Posts 7
    Martin you are a genius !!!!!
    I did not know this existed, the speed is now perfect . Thankyou
    I will also look into the lubrication issue when I have time ,I just get up quick at the end of the record at the moment.
    Thanks again
    Rich
  • 11-22-2011 3:57 PM In reply to
    • richh
    • Not Ranked
    • Posts 7
    Thanks for your input Soren , the speed issue is now resolved
    Rich
