Latest post 11-14-2011 12:29 AM by Hacoi. 8 replies.
Page 1 of 1 (9 items)
  • 11-07-2011 9:40 PM
    • Hacoi
    • Not Ranked
    • Joined on 06-15-2010
    • Vietnam
    • Posts 13
    Help..Help! Beocord 6500
    I have a Beocord 6500 which is now encountering some problems as follows:
    When I use a remote controller to play it at the side 1, the indicator light turns on (autorever), then flickers and finally turns itself off (the tape stops running). I try to fix with >> and <<, there is nothing happening except for some noise inside. I have replaced with a new bell, it remains the same.
    When I do the same with the side 2, the tape works smoothly as normal but >> and << do not.
    Sometimes, when I play, the tape works well at both sides, but other functions do not work.
    Wish to get your advice on these problem asap.
    Thank you so much,
  • 11-09-2011 1:30 AM In reply to
    • Hacoi
    • Not Ranked
    • Vietnam
    • Posts 13
    Re: Help..Help! Beocord 6500
    Please help me,
    Thanks!
  • 11-09-2011 2:22 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Is it only when you use the remote ?
    Is it reverting to standby when it stops ?
  • 11-10-2011 7:54 PM In reply to
    • Hacoi
    • Not Ranked
    • Vietnam
    • Posts 13
    Hi martin
    I not use remote, yes, is it reverting to stanby when it stop.
    Please I need help!
  • 11-11-2011 11:33 AM In reply to
    • Dillen
    • Posts 5,008
    Sounds like the overcurrent protection tripping.
    There is a service note for this if I remember correctly. I will check.
  • 11-13-2011 7:42 AM In reply to
    • Hacoi
    • Not Ranked
    • Vietnam
    • Posts 13
    OK, I will wait for information from you.
    Thanks so much
    Hacoi
  • 11-13-2011 9:08 AM In reply to
    • Dillen
    • Posts 5,008
    It was for the Beocord 5000 and it was in my own notes so sorry, I don't have any
    immediate clues.
    It will have to be diagnosed further, I'm afraid.
  • 11-13-2011 9:12 AM In reply to
    • Dillen
    • Posts 5,008
    Hold it.
    I just realized that it was Tim who had a similar Beocord on the bench a couple of years ago;
    Quote from Beocentral.com :
    "26th August 2008 by Tim Jarman
    This cassette recorder would play normally for up to ten minutes at a time before shutting down, necessitating the interruption of the mains supply to unlock the keypad so that operation could continue. This strange activity was due to the protection circuit operating, this stops the recorder if excessive current flows into the deck motors and solenoids. A long and protracted series of measurements proved that the reel motor circuit was the one that was triggering the overload condition but both the L272 motor drive IC and the reel motor itself proved blameless. Oscilloscope checks showed that the output voltage of the IC was unstable, resulting in it attempting to drive the reel motor in two directions at once. This of course resulted in an excessive current being drawn, operating the protection circuit.
    The datasheet for the L272 shows that when the device is used as a linear amplifier it is advisable to include a small filter network from the outputs to ground consisting of a 220nF capacitor in series with a 1R resistor. Adding these components to the Beocord 5500 circuit resulted in completely reliable operation, one wonders why the designers did not include them from new? [Beocord 5500]"
    Maybe this is what happened to your Beocord.
    I had a couple of similar cases that were somewhat closer to your symptoms but with the same cause.
  • 11-14-2011 12:29 AM In reply to
    • Hacoi
    • Not Ranked
    • Vietnam
    • Posts 13
    You can only the  serial number IC in side?
    Thanks Martin.
