1st March February 2012
10-24-2011 2:23 PM
Søren Hammer
- Joined on 01-07-2008
- Esbjerg/Denmark
- Posts 554
Beomaster 4400 - Capacitor replacement
Hello,
you might remember me posting about wanting to recap my 4400 a loong time ago. Now I finally have the spare time (sort of) to do it. Firstly, I think that this thread could be used as a general guide on dealing with these monstrous receivers. I thought it is strange that there apparently wasn't a thread dealing with the 4400 in details.
At first, I placed the 4400 on my lap and removed the veneer top cover and bottom cover. You should end up like this:
I have ordered the cap kit from Dillen (two in fact, as I also will restore my Father's 4400 after mine), it consists of nothing less than 56 discrete capacitors!
This is just the preparation of the project, need to buy a new soldering iron tomorrow before the fun can begin.
Any members who has good advice may post it here, have been wondering if I can remove the PCB's in the bottom of the unit to acess the solder side of the top PCB or should I work hard and remove the wiring looms?
-Søren
Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Re: Beomaster 4400 - Capacitor replacement
Just removed exess dirt from the middle plate behind the control panel - over 30 years of dirt collected on a bunch of cotton swabs, the last part removed with 99% isopropanol. It's a little hard to take a good picture of the situation.
chartz
- Joined on 07-20-2009
- Burgundy
- Posts 984
Well done Søren, but you might want to dismantle the fascia completely to have access to the switches which you will have to clean thoroughly.
Then everything else will be much easier to clean (wash, even) sans Q-tips!
Søren Hammer
- Esbjerg/Denmark
- Posts 554
That is actually a good idea, Chartz!
That also gives better acess to the PCB, I think. The faders could very well also use a clean-up.
Tried to power the unit on to be sure that it worked, last time I used it is around may. Pressed a random switch on the bank to turn it on. The "O. load" lamp briefly flashes and the protection relay steps into action. Something is clearly wrong, I must get it corrected before I begin to fit Dillen's set.
-Søren
Søren Hammer
- Esbjerg/Denmark
- Posts 554
The 4400 was handed over to a retired B&O technician, the problem turns out to be DC current leaking from one of the output transistors. Updates will come.
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
Gonna follow your thread with lots of interest Søren! Got one myself in beautifull condition, unfortanetely only one channel works...
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Evan
- Joined on 12-15-2008
- Ohio | USA
- Posts 2,601
Hi Soren,
Looks like a great project. Will you be doing the recap yourself, or has that been handed over to the Beo-tech also?
I wish I could be recapping with you but I don't have any caps!
Will be following this for sure!
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Thanks for the interest of my project. I will get the fault fixed, though I replace the capacitors myself.
Funny enough, the tech stated that "only the brown caps need replacing, the blue Philips electrolytics should still be fine". Are there anybody here who agrees with that?
chartz
- Burgundy
- Posts 984
My experience tells me that yes the blue Philips were reliable.
Sometimes they are fine, rarely they dry out, depending on use. As coupling capacitors they don't fail.
On my Beomasters they were generally still okay, but in doubt you might want to replace them and sleep on both ears!
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Søren Hammer:Funny enough, the tech stated that "only
Me, in principle... but they are old,
definitely already somewhat tired, and don't cost that much. You can't
be sure without measuring them, which would mostly be wasted time as it
won't take much longer to replace them anyway.
I'm generally
against component replacement when there's nothing wrong with them, but
as you've already found out, taking the Beomaster apart isn't a five
minute job, and it would be highly annoying to do it another time
because one of the "should be fine" components wasn't.
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
When the unit is open change all the e-caps, also the big ones, and the bridge rectifiers with some a little bigger, the big output darlingtons, if one is bad I change all of them, also check the thermal grease on the cooling elements, if dry clean and put on new grease.
I have my BM 2400 now open for the 3rd time because I didn't "do it all".
So dont leave anything where you have just a little doubt.
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Just got the 4400 back in business, it was ultimately proved to be a small signal transitor just before the output stage. It turned bad and one of the TIP transistors switched to put out DC.
chartz
- Burgundy
- Posts 984
That's great Søren... now playing with the big boys!
Congrats! What does it sound like then?
Søren Hammer
- Esbjerg/Denmark
- Posts 554
It sounds fine, but I want it to sound like it did 30 years ago. Beginning to look at the PCB's and schematics and heating the soldering iron.
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Turning the Beomaster upside down and removing the bottom plate again, removing the four screws on the backplate besides the DIN connectors for Tape 1, 2 and phono. The whole module can then be removed, take care as the PCB connector needs to be unplugged before removal of module.
Then I was ready to unsolder C6, a red 220 uF cap, I prepared my tin sucker to do the job. Then I realized that it was broken. Bugger. Going to the electronics store for the third time this week tomorrow.
Søren Mexico
- Mexico city
- Posts 1,621
Søren Hammer:Then I was ready to unsolder C6, a red 220 uF cap, I prepared my tin sucker to do the job. Then I realized that it was broken. Bugger. Going to the electronics store for the third time this week tomorrow.
If you were my pupil, you would have to sweep the workshop floor for a week, as punishment for not keeping your tools up to date, you knew the sucker was broken last time you used it
No, its very nice of you to mension this, we all learn as long as we live. Keep them coming, its going to be a very good BM.
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Now in action, starting with the smaller module PCB's.
The DIN connection module after firtting new capacitors - the 47 uF red cap replacement was not to be found in the kit.
Though all the rest are present, here are pictures of extra board #1:
Starting on the two red caps on the FM board now.
chartz
- Burgundy
- Posts 984
More, more!
And please welcome me to the club of 4400 owners!
Mine has a bad channel too it seems... waiting for the parcel to arrive!
Søren Hammer
- Esbjerg/Denmark
- Posts 554
I will see if I have the time to make more progress tonight - a large social science report has stolen quite a bit of my spare time this week.
And gongratulations with your 4400, hoping that the fault is easily fixable. My Father's 4400 just got the death scentence, the whole output stage, including small-signal transistors are gone unfortunately.
You should replace the capacitors
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Have been doing a bit of work on the 4400 now.
31 capacitors replaced, considering myself to be just about halfway done.
Martin sent me a PM about the missing 47uF caps, he kindly offered to send them, free of charge.
Now I move on to the more populated part of the main PCB, a bit tough to work around with.
chartz
- Burgundy
- Posts 984
Good!
There are lots of 1uF and 2.2uF plus some 4.7uF in there.
Has anybody tried 5mm Wimas in the 4400?
Evan
- Ohio | USA
- Posts 2,601
Søren Hammer: a large social science report has stolen quite a bit of my spare time this week
That happens to me every week! Although not necessarily a social science project - I finished all of those last year!
BTW, Looking good dude
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Thanks, Evan! Not having too much sparetime at the moment as I have to get a good outcome of my last year at upper secondary school
Chartz: It sure could be an interesting project, but way out of my league financially speaking! The 4400 design is exellent and I'm sure that exellent capacitors will make an even better receiver as the outcome
Replacement job almost done, 5 capacitors are left to replace, next up I want to clean the faders on the front panel
chartz
- Burgundy
- Posts 984
Søren Hammer:
That's funny, same thing here! An MPSA06. For testing purposes, I tested with a less powerful 2N3904 just to see what happens and we were back into business! I'm waiting for the real McCoy now, plus the cap kit from Martin. I ordered five of them, and I intend to replace it on the other channel too, since they seem to be prone to failure!
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Strange, my repairman said he had never experienced that failure before, and he had been working as a radio mechanic for B&O 1975-2000.
Installed the last caps and tested if it was working. No sound. Neither on FM...
Turns out that a couple of wires were disconnected (oops )
