Latest post 11-29-2011 9:27 AM by EdouardG. 2 replies.
Page 1 of 1 (3 items)
  • 10-15-2011 12:07 PM
    • EdouardG
    • Top 200 Contributor
    • Joined on 04-21-2007
    • Toulouse, France
    • Posts 339
    • Gold Member
    Tvix Slim S1 duo HD / "Guide" function (EPG) from beo6?
    Hi guys,
    I have the XML file to control the dvico Tvix slim s1 duo hd installed in the beo6, but don't find a button to control the EPG ("Guide" button on the tvix remote control).
    Could you please tell me if you have the XML file to add the EPG (Guide) function on the Tvix from beo6 or the IR code for this function?
    Let me know please.
    Thanks in advance.
    Best,
    E d o u a r d  G
    • Beovision 10-40 Orange MkII / Motorised stand / DVB HD T2/C MkIII
    • Beolab 5 Black
    • Beosound 8 Black
    • Beocom 2 MkII (Polished Alu)
    • Earset 2
    • Earset 3i
    • Form 2 Black
    • Beotime (Alarm Clock)
    • Keyring
    • Beo 6 / Wall charger
    • Beo 4
          °°°°°°°  2nd Prize Draw Winner - November '11 / Beolab 3000 N.O.S  °°°°°°°
  • 11-27-2011 5:06 PM In reply to
    • Alcorp
    • Not Ranked
    • Joined on 12-05-2009
    • Ã…rhus area, Denmark
    • Posts 4
    Re: Tvix Slim S1 duo HD / "Guide" function (EPG) from beo6?
    Hi...
    Wher did you find the xml-file?Smile
    I need the audio change buttom on my beo5, since I only habe the 6500 PUC in my BV7.
    Best,
  • 11-29-2011 9:27 AM In reply to
    • EdouardG
    • Toulouse, France
    • Posts 339
    • Gold Member
    Alcorp:
    Hi...
    Best,
    It's my dealer that installed it.
    As Keith told me, the PUC + XML files are in the B&O list.
    Drop me an email and I will send you the file I have.
    Or ask your dealer (or Keith) that could help you.
    Cheers,
    E d o u a r d  G
    • Beolab 5 Black
    • Beosound 8 Black
    • Earset 2
    • Earset 3i
    • Form 2 Black
    • Keyring
    • Beo 4
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
