Hi All!
Im a new user to this forum - hope I am adhering to all forum rules correctly!
Hope you can help me with the following few queries:
1. Im trying to connect my BS9000 Mk2 (Purchased end of '99) - to my Loewe Individual 46" via digital out, when i connect it up, i play music and it should come through the tv - but i dont get anything - i tried the same digital in on the tv via a loewe blu-ray and it works, so i know the tv is working fine.
is there any setup i need to do on the actual BS9000 unit for activating the Digital Out or to enable it to work with a non b&o product?
2. My Old Avant 32" VHS - only works with the original Sky Digital around '99, i need it to work with Sky+, is there any way to upgrade the software/firmware on the tv to let it work with Sky+?
3. I've seen you can put a shelf on the back of the tv, which usually houses DVD1 - where can i get this from and how much is it?
4. The Plates at the back of the tv which currently let the original sky digital box sit vertically, doesnt let a sky+ box sit in there properly due to the dual SAT inputs - is there a modified plate anywhere that can house the Sky+ box?
Many Thanks for any input!
Jay
