Latest post 09-28-2011 9:33 PM by jvezina. 2 replies.
Page 1 of 1 (3 items)
  • 09-28-2011 5:41 PM
    • kai
    • Top 500 Contributor
    • Joined on 11-16-2008
    • Posts 81
    Beosystem 3 and old mac mini
    Just had a customer have is beosystem 3 to the latest software and all seems fine. I have put his mac mini into the system this is an older mac with 1.83ghz processor and dvi connection problem seems to be resolution I gone into preferences and to display selected 1080p and clicked overscan however I still missing the bar at display bar at the top of the screen so I can't see time etc, have tried various resolutions but can't get it quiet right has anyone come across this?? I should say it's a bvis 4.65 mk2
  • 09-28-2011 8:40 PM In reply to
    Re: Beosystem 3 and old mac mini
    I have the same mac mini connected to beosystem3 and i have the same problem...
    Try lower resolutions.
    Or change picture settings of the monitor.
    I came to realise that When i set resolution to 1080p, the picture setting on my tv(samsung 52lvxxxx four year old lcd) must be on "just scan" not "16:9" or "zoom"...
    BL5 (pair), BL3 (pair), BL7-2, Beosystem3 w/dvb-s, cabinet, BS4 w/DAB, BV8-26 w/sys module, Beocom 2, Beo5, Beo4, Beoport, A9 and a garbage DVD2
  • 09-28-2011 9:33 PM In reply to
    Select FORMAT 1 on the Beo 4. The picture should be complete. This is what I am
    doing when I connect my Macbook Pro to my Beovision 7 MK III
    Good luck,
    Jean
