Latest post 09-29-2011 2:08 AM by Keith Saunders. 1 replies.
Page 1 of 1 (2 items)
  • 09-28-2011 3:14 PM
    • biebme
    • Not Ranked
    • Joined on 09-28-2011
    • Posts 1
    • Silver Member
    Beo5 configuration
    Hello everybody
    Can anybody help me configure my beo5 to work with the Yousee box (Samsung SMT-H3126)
  • 09-29-2011 2:08 AM In reply to
    Re: Beo5 configuration
    A Very Warm Welcome to Beoworld..
    To control your Samsung PVR you will need to have an XML control file made which allows it to be added to your Beo5 configuration in the B&O Configuration Tool.
    Before that XML file can be made, we need to establish the IR (Infra-Red) codes for each command of this unit.
    These IR codes may be available on the web in the form of Pronto HEX codes or you can capture these codes from your original remote control if you have an IR capture device such as a Lintronic box or similar. The best starting places for IR codes on the web is at http://www.remotecentral.com/cgi-bin/codes/
    As Samsung products are not always made by Samsung themselves, using IR codes for another apparently similar device may or may not work therefore it is always best to establish the actual devices IR codes.
    Regards Keith....
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
