Latest post 09-28-2011 11:08 AM by Opman. 1 replies.
Page 1 of 1 (2 items)
  • 09-28-2011 8:02 AM
    BEOMEDIA 1 AND BEOVISION AVANT
    Hello,
    I just bought a used one has beomedia brnacher on my BeoVision Avant RF. I also have a BeoSound 9000 MKI.
    I managed to connect the image and sound of the BeoVision 1 BEO before but it is not possible to navigate or operate the beomédia with a BEO 4 REMOTE CONTROL.
    I did not connect the IR sensor.
    Someone please advice
  • 09-28-2011 11:08 AM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: BEOMEDIA 1 AND BEOVISION AVANT
    From memory you need to connect the ir sensor to BeoMedia1 when using an Avant (or any other TV that doesn't recognise the "PC" command).
    Opman
