Latest post 09-22-2011 12:04 PM by Medogsfat. 3 replies.
Page 1 of 1 (4 items)
  • 09-20-2011 9:02 AM
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Plastic frame for Beocenter
    Hi all - I know there are hundreds of non-working Beocenter 9000's out there so if someone could sell me a plastic frame for the bottom glass panel I'd be grateful.
    I need the bottom right hand side/end section only. All of the frames are identical for the whole series of this design of Beocenter so one from a 8000/8500 or 9500 will do.
    Chris.
  • 09-20-2011 12:18 PM In reply to
    Re: Plastic frame for Beocenter
    I will put one in the post tomorrow, Chris.Cool
    Regards Graham
  • 09-20-2011 1:01 PM In reply to
    • Medogsfat
    • Posts 4,045
    Thank you very much Graham. You know where I am if you need a return favour.
    Chris.
  • 09-22-2011 12:04 PM In reply to
    • Medogsfat
    • Posts 4,045
    Arrived - installed - looking & working great.
    Cool
    Chris.
