1st March February 2012
Latest post 09-19-2011 12:05 PM by EdouardG. 8 replies.
09-19-2011 7:06 AM
EdouardG
- Joined on 04-21-2007
- Toulouse, France
- Posts 339
Masterlink Cable / Chimney
Hi guys,
I think about placing my BS8000 as front speakers for my BV10, but want them to be linked to the BS9000 too.
The problem is that there's a chimney between both the BV10 and the BS9000.
Here is a shot showing my living-room so that you understand my set-up:
What do you advise me?
Is there any risk of damaging the masterlink cable with the chimney working if stuck all around it?
Let me know please.
Cheers,
E d o u a r d G
- Beovision 10-40 Orange MkII / Motorised stand / DVB HD T2/C MkIII
- Beolab 5 Black
- Beosound 8 Black
- Beocom 2 MkII (Polished Alu)
- Earset 2
- Earset 3i
- Form 2 Black
- Beotime (Alarm Clock)
- Keyring
- Beo 6 / Wall charger
- Beo 4
°°°°°°° 2nd Prize Draw Winner - November '11 / Beolab 3000 N.O.S °°°°°°°
Vienna
- Joined on 08-15-2008
- make an educated guess
- Posts 712
Re: Masterlink Cable / Chimney
Is there an antenna socket on the wall where your BSd 9000 is located? There also shoud be a distribution "point" for all areal cables. Sometimes the diameter of the cable conduit is sufficient for a 2nd cable (e.g. if inner diameter of the tube ~ 20mm).
If 3 times "yes" >> try to pull the ML in parallel to the antenna cable.
(Maybe you'll have to deinstall the antenna cable(s). Then pull ML and antenna "together" through the cable conduit.
EdouardG
- Toulouse, France
- Posts 339
Vienna:
Hi Vienna,
Always here when I need you ;)
No, there isn't an antenna socket behind the BS9000.
But I just want to put a ML cable between the BV10 and BS9000 to use BL8000 on both systems.
Here is what it would look like:
My only fear is to burn the ML cable if placed on the chimney.
Cheers,
E d o u a r d G
- Beolab 5 Black
- Beosound 8 Black
- Earset 2
- Earset 3i
- Form 2 Black
- Keyring
- Beo 4
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
EdouardG: Is there any risk of damaging the masterlink
Failing Vienna's better idea of routing through existing conduits...:
That
of course depends on how hot your planned routing for the cable gets.
Regular PVC-insulated cables should easily hold 60-70°C, which is
already hotter than you can comfortably touch.
But you would need to somehow cover the cable in any case. I think I'd try installing the cable behind the floor skirting, which shouldn't get hot either.
Vienna
- Posts 712
tournedos: I think I'd try installing the cable behind the floor skirting, which shouldn't get hot either.
Runnig the cable behind the baseboard is an excellent solution as long you can detach the skirting easily.
As an alternative, a skilled B&O installer should be able to cut/carve/scratch a "dent" into the plaster (just above the baseboard) and cover the cable/fill the gap with silicone/acrylic sealing compound afterwards.
PS: regarding the temperature floor level is a very safe area - heat ascends ...
PPS: ... good opportunity to run an antenna cable for FM from the aerial outlet of your TV to the BSd 9000 in parallel ...
ajames
- Joined on 05-04-2007
- Posts 275
I think I'd consult a builder as maybe it would be possible to take up some of the tiles and have a channel cut and then the cable laid in there and the tiles laid back on top. Other thoughts are to find out what's on the outside of the walls the products are on as the cable could go round the outside of the house in a suitable conduit.
Whatever you do though it does look beautiful with the bl8000 either side of the TV.
Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
Any chance you got Ethernet/RJ45 wall plates where the BS9000 and the BV10 is...?
You could use those to establish a cable connection between the two systems.
Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
EdouardG
- Toulouse, France
- Posts 339
tournedos:
That
Vienna:
As an alternative, a skilled B&O installer should be able to cut/scratch a "dent" into the plaster (just above the baseboard) and cover the cable/fill the gap with silicone/acrylic sealing compound afterwards.
PPS: ... good time to run an antenna cable for FM from the aerial outlet of your TV to the BSd 9000 in parallel ...
Thanks for your help!
I'll try to go through the plaster and put the ml on the floor and let you know.
Cheers
E d o u a r d G
- Beolab 5 Black
- Beosound 8 Black
- Earset 2
- Earset 3i
- Form 2 Black
- Keyring
- Beo 4
EdouardG
- Toulouse, France
- Posts 339
ajames:
Hi ajames,
Thx for your reply.
But I cannot do what I want in my house, as i'm not the owner.
Can only make a little hole in the chimney (that could easily be filled when I leave the house) and go through it with my ML cable.
kallasr:
Ralf
Hi Ralf,
Unfortunatly, I don't have any ethernet wall plate in my house.
But that would have been a good idea!
Cheers guys
E d o u a r d G
- Beolab 5 Black
- Beosound 8 Black
- Earset 2
- Earset 3i
- Form 2 Black
- Keyring
- Beo 4
Page 1 of 1 (9 items)
