To
upload one pic to a reply, place you curser where you want the pic,
pick, above the reply frame, OPTIONS, pick ADD/Update, in the pop up
frame pick Browse, find the pick in your comp. click open, in the
frame click save, go back to compose, the pick will be uploaded when
you post your reply.
Or like this if you
want more pics in the same reply.
First go to your
account, upper right corner, click signed in as, scroll down click
"my files", down left you have browse and add file, on the
right add folder, if you want to create diff. folders, enter folder
name and click "add folder", open folder, now click
"browse", in your computer find the pic you want to upload,
click "open". Now click "add file", your pick
will upload and show in the folder, next pic same.
to post a pic, open
your new thread or reply to one, text your answer or opening remarks,
click the film strip in the menu, click "browse",
Your files will
show, click the folder with the pick, double click the pick, the pick
will show where your curser was placed before you clicked the film
strip.
Before uploading,
edit your pics down to some 640 x 480 pixels, that will give you a
faster upload and the pic will fit to a forum page.
Saludos Soren
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
