Latest post 09-09-2011 7:54 AM by chartz. 5 replies.
Page 1 of 1 (6 items)
  • 08-25-2011 11:29 AM
    • chartz
    • Top 75 Contributor
    • Joined on 07-20-2009
    • Burgundy
    • Posts 984
    • Gold Member
    Beogram CD5500 and Beomaster compatibility
    Hello,
    Is the Beogram CD5500 compatible with the Beosystem 5000? Will the terminal be able to control it and display its tracks/times correctly?
    Jacques
  • 08-25-2011 11:59 AM In reply to
    Re: Beogram CD5500 and Beomaster compatibility
    I am sure that the CD5500 is backwards compatible to the 5000 system, as the CD50 works fine with my Beosystem 5500.
    AFAIK, the same DataLink system is the same for CD50 and CD5500.
    -Søren
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 08-25-2011 1:09 PM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Thanks Søren. Can anyone confirm this please?
    Jacques
  • 08-25-2011 1:34 PM In reply to
    Yes, it is fully Beosystem 5000 compatible.
    Regards Graham
  • 08-25-2011 1:38 PM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Thanks Graham. Smile
    Jacques
  • 09-09-2011 7:54 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Well finally I went for a Beomaster 5500!
    Jacques
