Latest post 08-20-2011 12:24 PM by solderon29. 1 replies.
Page 1 of 1 (2 items)
  • 08-19-2011 4:31 PM
    • timbo
    • Not Ranked
    • Joined on 08-19-2011
    • Posts 1
    Beovision MX 4000 Dropping into Standby
    Elderly neighbour has asked me to look at his MX4000.
    After switching on (TV or Video/DVD), it drops back into standby mode after about 10-15 minutes.
    Ideas?
    Is it worth repairing?
    BTW - when it runs the picture is fine and in every other respect the TV is OK.
    He has given it to me, so shouild I get it fixed or take it to the City recycling centre?
    Tim
  • 08-20-2011 12:24 PM In reply to
    Re: Beovision MX 4000 Dropping into Standby
    This is a very common problem with this chassis.The set has a safety protection system that will shut the set down (standby)in case a fault occurs.
    However,in many cases this can also be due to "dry" soldered connections in the power supply stages,particularly C12,adjacent to the main smpsu transformer
    It's well worth checking this,but make sure all power is disconnected before delving inside telly's ,they are dangerous places!!!
    If in doubt,take it to a B&O service agent,it's well worth repair
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
