Latest post 08-09-2011 1:30 PM by Dillen. 15 replies.
Page 1 of 1 (16 items)
  • 08-05-2011 2:43 PM
    • chartz
    • Top 75 Contributor
    • Joined on 07-20-2009
    • Burgundy
    • Posts 984
    • Gold Member
    Beogram 5005 lid adjustment
    Hello!
    So I've got myself a nice Beogram 5005 for a miserly 50€.
    It works, but the MMC4 has lost its stylus and cantilever!
    How can you adjust the lid?
    The hinges are fine but its depth is wrong. There is a clear gap at its back, and it protrudes at the front.
    There must be some kind of adjustment, surely?
    Thanks!
    Jacques
  • 08-06-2011 2:04 AM In reply to
    Re: Beogram 5005 lid adjustment
    I have had many of these in pieces and I cannot remember any type of adjustment on the lid.
    Regards Graham
  • 08-06-2011 2:15 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Thanks Graham.
    What am I supposed to do then?
    Nothing looks broken or displaced, and the overhang is symetrical. It leaves a 4 mm gap between the cover and the back.
    Jacques
  • 08-06-2011 3:51 AM In reply to
    Just to make sure, have you seen one of these decks up close before? That stupid 3-4 mm gap belongs there. The front should be more or less flush, however Hmm
    Can't remember any adjustment as such either. Perhaps some of the mountings allow for some play, I dunno...
    -mika
  • 08-06-2011 4:13 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Thanks Mika.
    No, this is my first.
    More or less flush... Okay then.
    They are all like this?
    Jacques
  • 08-06-2011 9:58 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    By the way, there is no 33/45 indication, just two red lights. Is anything missing?
    Jacques
  • 08-06-2011 12:45 PM In reply to
    chartz:
    Probably the plastic window that has the fake 7-segment displays Sad
    (and yes, as far as I know the lids are all like that, no matter which model)
    -mika
  • 08-06-2011 2:12 PM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Thanks for the piccy Mika.
    Where on earth will I find one?
    Not inside the deck mind you, I've already been there!
    Jacques
  • 08-06-2011 3:08 PM In reply to
    Perhaps somebody has a spare indicator arm - AFAIK it's the same regardless of the model or colour of the deck.
    But, it shouldn't be too difficult to fabricate a replacement window. I would start with laser printer proof overhead projector slides, then some diffuser film (scratched plastic or thin white paper)...
    -mika
  • 08-06-2011 4:33 PM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Or Letraset transfers and black and white film...
    Jacques
  • 08-08-2011 5:30 PM In reply to
    I have a spare arm!Devil
    Regards Graham
  • 08-08-2011 5:48 PM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Thanks Graham - I do appreciate this!
    Your smiley also put a big smile on my face!
    Anyway, I will decline your friendly offer because another member actually did the same.
    I now have to send the MMC over to Axel and I will be able to run comparisons with the other Beograms I've got - 3000, 4000 and 8000!
    Jacques
  • 08-09-2011 5:03 AM In reply to
    No problem.
    Regards Graham
  • 08-09-2011 10:40 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Hello!
    Well I've skimmed the Web, especially UTube and it seems that many actually don't have the fake digital indicator...
    A common problem then?
    Jacques
  • 08-09-2011 11:40 AM In reply to
    I must have had in excess of 50 of these decks over the years and I have never seen one without the correct indicator!
    Regards Graham
  • 08-09-2011 1:30 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Me neither.
