Latest post 08-05-2011 1:33 PM by Vienna. 1 replies.
Page 1 of 1 (2 items)
  • 08-05-2011 12:08 PM
    • Marcus
    • Not Ranked
    • Joined on 07-26-2011
    • Karlstad, Sweden
    • Posts 15
    BeoLink Eye help needed quickly!
    Hi!
    I just bought a BeoVision 4-50 with BeoSystem 2. When I came home I noticed that the IR-receiver unit where missing. I will get it shipped to me in two weeks. So I thought that I could use my BeoLink Eye from my BeoLink Aktive during this time. But there is a different connector on the cable. So what I need to know is the pin configuration for the 8-pin mini din in my BeoSystem and what cables to connect in the other end (BeoLink Eye) There is 5 cables in there (yellow, grey, green, white and brown). I can not find what the do in any documentation.
    So if anybody knows anything about the pin configuration of the 8-pin mini din and the BeoLink Eye I would really like to know :-)
    Thanks a lot!
    /Marcus
    BeoSound 9000 MKII
    BeoSound 3200
    BeoVision 4-50 MKIII (BeoSystem 2 MKIII)
    BeoLab 3
    BeoLab 2
    BeoMedia 1
    HDR1
    BeoCom 2
    Beo4 MKI, MKIII
    Beo5
    Keyring
  • 08-05-2011 1:33 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: BeoLink Eye help needed quickly!
    If your BeoSystem 2 is a (HD-ready) MK3 version you'll need:
    8089000 IR-sensor with auto contrast
    6277910 Wire f/IR-sensor with auto contrast (9 pin mini DIN)
    MK1 and MK2 versions of the BSy 2 used:
    8089110 IR-sensor without auto contrast
    6270758 Wire for IR-sensor (3,5 mm mini jack)
    Maybe a "BeoLink PC2 / BeoPort / Avant US" IR sensor will also work,
    if your BSy has an 3,5mm IR INPUT in addition to the STB-IR OUTPUT
