Latest post 07-27-2011 4:48 AM by stefan. 1 replies.
Page 1 of 1 (2 items)
  • 07-27-2011 4:06 AM
    how to wire 8 pins din to a RCA connector?
    dear all
    How can i wire 8 pins din [to replace the powerlink] to an RCA connector on the other end[none b&O equipment]
    The reason being ,my wires are already installed in the wall.
    The wire I used is just normal speaker cable,do I need  shielded cable?
    Has anyone got a diagram how to sold them on the din and on the RCA?
    thank you for replying
  • 07-27-2011 4:48 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: how to wire 8 pins din to a RCA connector?
    Welcome to Beoworld.
    You will find a lot of information about wiring, options, setups... on the Beotech site:http://www.beoworld.org/beotech/wiring2.htm
    What Beo do you want to replace? Beomaster (amp) or Beolab (speaker)? Powerlink cable is built for line level signals, it`s connecting preamp out (Beomaster or Beovision) and poweramp in (Beolab). It`s shielded and or speaker level signals rather thin... But maybe you can combine two pins of Powerlink for speaker speaker cable....(?)
    Stefan
