Latest post 11-27-2011 3:46 PM by StUrrock. 6 replies.
Page 1 of 1 (7 items)
  • 07-22-2011 6:55 AM
    • gysse2004
    • Not Ranked
    • Joined on 05-19-2009
    • Copenhagen North
    • Posts 42
    Beringer UCA 222
    Just got the Beringer UCA222, and connected to Beomaster5 via USB - streaming sound via Airport Express.
    The problem is that in the beginning of the streaming process, the sound "stutters", like digital stutter- if i restart the song a couple
    of times it goes away.
    i tryied to connect my Iphone aswell, but the problem remaims. Has anybody experienced the same ?
    I am thinking of getting a different soundcard, mayby ESI U24.
  • 07-25-2011 3:34 PM In reply to
    Re: Beringer UCA 222
    Hey there. Would the ESI U24 give you digital input from the Airport Express digital out? I have the Beringer UCA222 but feel the sound could be better if fully digital.
  • 07-25-2011 4:52 PM In reply to
    • gysse2004
    • Not Ranked
    • Copenhagen North
    • Posts 42
    It does have toslink indput, i have ordered one, so if you have a little patience, i Will Update in a week or so, when i have one. And yes the Sound quality of the uca222 if poor.
    Peter
  • 08-02-2011 2:42 PM In reply to
    • gysse2004
    • Not Ranked
    • Copenhagen North
    • Posts 42
    ESI 24XL did not work !
    Mayby because it requires a driver, i think it needs plug and play.
    Peter
  • 08-06-2011 3:39 PM In reply to
    • gysse2004
    • Not Ranked
    • Copenhagen North
    • Posts 42
    Has anybody had any luck with other soundcards then Beringer 222 ?
    There must be somthing better, my setup is BS5, With Beolab 5 -
    so having a 40€ soundcard, dosent seems to match.
  • 11-27-2011 12:52 PM In reply to
    • tompa
    • Top 500 Contributor
    • Joined on 06-30-2007
    • Sweden
    • Posts 94
    gysse2004:
    Only Beringer 222 works because b&o have this driver installed in sw
    if you want to use another soundcard you have to manual install driver for it in servicemenu (xp windows) but after sw update you have to do it again...
  • 11-27-2011 3:46 PM In reply to
    • StUrrock
    • Joined on 02-04-2008
    • Cambridgeshire
    • Posts 219
    We are letting Bang & Olufsen off the hook big time here! This thing costs nearly £5K!!
    • From Day 1 the BS/BM 5 should have had a high quality analogue aux in fitted as standard. Without the nead for digital processing with very so so sound quality.
    • From Day 1 the BS/BM 5 should have had an in built CD ripping would have cost peanuts, they bring out the new ripper solution and expect us all to nominate them for the nobel prize for technology!
    • At this price you would expect the manufacturer to have an app out in their own name.
    Great sounding product with some nice features, but the shortcomings are so frustrating!
