Latest post 07-22-2011 10:20 AM by Mindphaser. 3 replies.
Page 1 of 1 (4 items)
  • 07-19-2011 12:06 PM
    Beovision 6-22 vs Beocenter 6-23
    Hello there,
    this is my first post here on Beoworld Smile !
    So, i'm from Italy; i love B&O and iconic electronic objects since my teen years (Loewe,Brionvega, B&O of course) !
    Just days ago i won this auction, from the gentlemans of Lifestyle AV (i know Lee is here on the forum;is Matt here too?)
    http://cgi.ebay.it/ws/eBayISAPI.dll?ViewItem&item=320723768796&ssPageName=STRK:MEWNX:IT
    Well, to be totally honest my real target was the Beocenter 6-23
    http://cgi.ebay.it/ws/eBayISAPI.dll?ViewItem&item=320723766904&ssPageName=STRK:MEDWX:IT
    But you know how eBay is, i was outbid by 0.50 £ or such Angry
    Well, i just would like to make a couple of questions,since i'm new on the B&O world:first,  are Video use 998 days; On/Off 11860 times. good values or means the the TV was used daily ? I just don't know how to interpret those numbers.
    I know that the TV is 7 years old, but what does means 998 days of use? should i do 998/24h ?Confused Or does it means that for 998 full days the TV was straight in use ?
    Btu my real question is: is there  so much difference between 6-22 and Beocenter 6-23? DAB Radio sure, but LCD-wise?
    I know that the Samsung panel of the 6-22 was not so great (poor viewing angle, Contrast ratio  500:1 (min. 400:1 at center of the screen); infact the 6-26 was fitted with a Sharp panel.
    But with my surprise, the Beocenter 6-23 screen (btw, who is the producer? Samsung? Sharp? ) seems to be not so better (3 years between the 2 products) , with only 800:1 contrast.
    Loudspeakers are identical (bass reflex);exterior-wise for sure Beocenter is better (the grille,the color)...but i wanna know: are the tto products so different speaking of LCD;or are only slightly different? Of course i don't care about 22" or 23" difference, i'm just speaking about quality !
    Any owners that can make a comparison between the two?
    Long life to B&O !
  • 07-22-2011 6:17 AM In reply to
    Re: Beovision 6-22 vs Beocenter 6-23
    No answer ? :(
    Maybe i should have posted htis under the 'General' section,but since i bought my BV6 on eBay...BTW;searching Beoworld froum i found some interesting threads like
    http://forum.beoworld.org/forums/p/33686/276765.aspx#276765
    http://forum.beoworld.org/forums/p/37468/311511.aspx#311511
    Btu still i don't knwo if Beocenter6 screen is so better than BV6 one.
    I don't need DVI port or DAB radio, i just wannak now about LCD screen quality :)
  • 07-22-2011 7:22 AM In reply to
    • h1npw
    • Top 75 Contributor
    • Joined on 04-16-2007
    • A cricket ball throw from Trent Bridge
    • Posts 776
    Welcome to Beoworld!
    It is most unusual for first time posters with questions not to get a quick response. I'm sure if you posted in the General forum you would get a response in minutes!.
    I'm afraid I can't help you as I have absolutely no knowledge of B&O TVs!
    Cheers
    Nigel
  • 07-22-2011 10:20 AM In reply to
    Thanks for the kind welcome Nigel;
    i'll try to post it in the General Section rigth now !
