Latest post 12-05-2011 5:35 AM by beowild. 1 replies.
Page 1 of 1 (2 items)
  • 06-24-2011 10:27 AM
    • Kokomo
    • Top 100 Contributor
    • Joined on 08-21-2007
    • Spain
    • Posts 618
    Beomaster 4500 - clunking noise
    I have a Beomaster 4500 and if I have to umplug from the mains for any reason, I really dread having to plug it back in as this always results in a brief but quite loud electronic 'clunk' through the speakers. It's always been like that and doesn't seem to have any adverse effect but I just wonder if this is normal. Does anyone else with one of these units experience this?
    Finally, is it OK or should I be concerned (after all these years!).
    Thanks.
  • 12-05-2011 5:35 AM In reply to
    Re: Beomaster 4500 - clunking noise
    Hi
    I also have one of these beomaster 4500. When i tested the installation and the options in the connected rooms, i also had to separate the bm4500 from the mains a lot of times. I also experienced this clunking noise so i think it is normal with these units (not designed to separate all the time). What you can do is to diconnect the speakers before you reconnect.
    I also appreciate the bm4500 for his optical and sound quality.
    Best regards
    David
