Latest post 06-19-2011 9:30 AM by Electrified. 4 replies.
Page 1 of 1 (5 items)
  • 06-18-2011 9:04 AM
    volume syncro
    It would be great if B&O makes in the next software update a volume syncro function for the beosound 5.
    Some songs are much to loud and that's very anoying.
  • 06-18-2011 10:36 AM In reply to
    Re: volume syncro
    Hi
    I wouldn't prefer to have the sound synchro.
    I listen to 192kHz & 96kHz "unlimited tracks". These should sound softer because they are mastered to get the whole dynamic range of the hi-res. Remastered cd are often limited so they sound "better". This is partly done by let them sound louder. So if programmed; always the possibility to switch the synchro of!
  • 06-18-2011 10:44 AM In reply to
    • Electrified
    • Top 150 Contributor
    • Joined on 10-05-2009
    • Greater Copenhagen, Denmark
    • Posts 404
    Re: volume syncro
    Classical music and operas spring to mind where I don't want auto-levelling.
  • 06-18-2011 11:41 AM In reply to
    Re: volume syncro
    You can always make the choice  on/off.
  • 06-19-2011 9:30 AM In reply to
    • Electrified
    • Posts 404
    Re: volume syncro
    koning:
    Yup. If implemented, it should be a choice. Either globally and/or per track/album
