Latest post 06-16-2011 11:47 AM by Blackrix. 1 replies.
Page 1 of 1 (2 items)
  • 06-15-2011 5:15 PM
    • arhk05
    • Not Ranked
    • Joined on 06-07-2010
    • Posts 6
    My MX1500 lost its sound and color
    Hey guys.
    My MX1500 has lost its sound and colors, I've just read that the colors may be do to a failure of the battery. Thanks for that. But what  the sound? Is that do to the battery failing as well or is it just broken? And can I fix it my self?
    I'm new to the world of B&O and there any guidance is appreciated
    Thanks in advance
    Anders
  • 06-16-2011 11:47 AM In reply to
    Re: My MX1500 lost its sound and color
    If you know how to handle a soldering iron you can replace the back-up battery. I would replace it and see of the other problems also are solved. The battery is not the most expensive part.
