Latest post 07-05-2007 7:49 PM by Frank Rizzo. 5 replies.
Page 1 of 1 (6 items)
  • 07-04-2007 11:40 AM
    Beomaster 6500 as a preamp using powerlink outputs to an external amp
    I am running some non B&O speakers that need for than the 50wpc than the Beomaster 6500 can provide. Has any successfully and sonically used a Beomaster 6500 as a preamp using the powerlink outputs?  Thanks.
  • 07-04-2007 6:16 PM In reply to
    Re: Beomaster 6500 as a preamp using powerlink outputs to an external amp
    Yes, I sold a BM6500 to a customer who was going to use it to feed a QUAD power amp via powerlink. It was a couple of years ago and as far as I know, all went well.
    I remember that we arranged to meet at a farmer's grass air strip. The guy arrived in his private plane, collected and paid for the amp and off he flew. Had a few phone calls about making up a suitable cable but after that nothing.
    I have personally used a BC9000 as a pre amp to feed a QUAD with quite remarkable results. The combination made a pair of RL140's come to life in spectacular fashion.
    Regards Graham
  • 07-04-2007 7:08 PM In reply to
    Graham's right...we took the powerlink off an active kit, converted it to RCA with the simple adapter and ran it into a yamaha M60 amp, then to 3 sets of yamaha speakers. At 160rms a channel and almost no distortion it sounds great. So, the powerlink off your 6500 can't be any different.
  • 07-05-2007 10:04 AM In reply to
    Thanks. Where can you obtain the adapter?
  • 07-05-2007 11:12 AM In reply to
    Basically you need to make it yourself with a couple of RCA plugs and a 5 pin din plug plus a couple of lengths of screened cable.
    Regards Graham
  • 07-05-2007 7:49 PM In reply to
    Graham's right...or just go to Ebay and type search B&O and RCA converter...be sure that you buy the powerlink (for output) converter not the AUX converter...
    the BnO store has these....powerlink converter to RCA's...
